D-17 gas gauge float
22-shotgun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 22-shotgun Quote  Post ReplyReply Direct Link To This Post Topic: D-17 gas gauge float
    Posted: 20 Dec 2015 at 12:04pm
Hi all, I'm new to this site and the Forum thing. I have a great little D-17. My question is trying to find something to replace my gas gauge float. I was told cork will not work with the ethanol in the gas, that's probably why mine sinks and coating it with something will just disintegrate off. Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 1:10pm
I just use 1/2 of a float from the junked Cavaliers I've disposed of around here. Now you can buy new floats but well I'm cheap AND frugal ! I even found another complete fuel sending assembly(pump,float,etc.) today when I kinda cleaned up here,yeesh....maybe I'm a packrat ??
Jay
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 1:45pm
There is a guy in IL that sells floats for some kind of model (maybe an A ) Ford.
I
I lost his ID, but got one for the D 15.
I swear D series 4 gave me the source.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 2:21pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 4:55pm
Cork will work fine if coated with SealAll. Has been working for me for decades on the float in my MF-135 that runs fine on E10.
Gerald J.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 8:36pm
I sell the new floats.
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 8:42pm
22-Shotgun, welcome to the forum.  We love to see pictures, so keep us posted on your D-17.  I can't help with floats, but glad to have you on the forum.
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2015 at 9:28pm
Are you sure your float is sinking?  If it is reading empty, the most likely cause is the float riding up and down on the rod rather than staying at the end of it where it belongs.
If your float is still bad, I use new ones that are made of neoprene (will not disintegrate in gas).  There are around $4 a piece from a place called Old Standard Auto Parts - the carry stuff for Ford Model A's.  Their number is 866-654-2855866-654-2855 FREETalk to Kevin there and mention part number A-9313-C.
Edited by DSeries4 - 20 Dec 2015 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 8:10am
to the forum!!  Where bouts in MN are you?  Best bet is what DSeries4 told you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 4:28pm
When i called that guy up about a float he chuckled and remarked, You must have some kind of AC.  LOL
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 4:37pm
I picked one up from Kevin last spring when I planned on taking the tank off to clean it. After removing the gauge, I placed the outside end of the "wire" on an anvil (back edge of the vise) and tapped on the swedged part to bring it back close to round. Slide the old float off along with the retaining washer and slide the new Neoprene float on. Replace the washer  and place the "wire" back on the anvil and hammer lightly till the washer can't slide off.
 After I got done, I thought " I should have taken pictures or video" Oh well hind sight is always better Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote 22-shotgun Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 10:19pm
Thanks everyone for the help. DSeries4 it's not sliding on the rod, when I looked in the tank it was below the gas level. Will give the neoprene a try as Minnesota requires gas to have ethanol in it. Ted J, Fergus Falls.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2016 at 7:13am
I'd get one from Norm.
Dusty
