D17 gas alternator mount help needed
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Topic: D17 gas alternator mount help needed
    Posted: 10 Dec 2010 at 7:07am
Does anyone sell a mounting bracket to put a Delco 10SI alternator on a D17 gas? I have built them before, but if someone offers one at a fair price I would just buy it and save the time. Also, is there any reason the brackets off of a 170 gas would not work?  Anyone parting out a 170 gas?
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 8:58am
I am putting a different motor in a D17 gas. It had a Delco 10si on it. I am 40 miles from you and it would be easier to just make a bracket than drive for this one.
I am the fellow that asked you about tolerance of hooking 2 flywheels together.
I bought a Gleaner combine motor so they  have the same father and bolt together.
I would have been in over my head with the Perkins engine. I don't have the machine tools or the measuring equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:01pm
Thanks for the reply. What Gleaner engine are you using? How is the alt bracket that you have made? Is it 2 bent straps that come straight up from the engine plate or a one piece bracket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 1:44pm
A 301 diesel from an F2. Seems not to be any bad problems so far. I have the clutch housing bolted together. Frame rails next.
The bracket is an H shaped weldment of 1/4 x 2 down to the piece of steel between the engine and frame rail.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 2:09pm
You can also check with SteveNJ. He provided a mounting bracket to me when I installed the 10SI on my CA.
This page was generated in 0.099 seconds.
