D17 fuel gauge
alc609 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Topic: D17 fuel gauge
    Posted: 20 Jun 2017 at 4:37pm
Anyone know where I can get the gasket that goes behind fuel gauge? Or am I going to have to make one?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 4:54pm
AGCO has them.  Pretty cheap too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 5:46pm
DJS Tractor Parts that advertises on here has them also.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:00pm
DJS would be my first choice.  Might want to pull it first and see though.  I had to pull mine and it was already switched from cork to rubber and I was able to reuse it.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote alc609 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 6:21pm
Mines starting to seep around it if full of gas.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 7:28pm
I use the larger sediment bowl gasket like the D17 Diesel uses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 8:55pm
Take your gauge with you to the hardware store or auto parts store and get an O ring that fits around the gauge body. That's what is sealing the gauge to the tank on mine.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2017 at 8:19am
I've got the gasket...6.00, plus the ride.   Rick
This page was generated in 0.270 seconds.
