D17 Front Support Picture |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 475 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Mar 2019 at 2:41pm |
D17 front support seems to be wallowed out. Not sure how much build it up. Anyone have a picture or measurement would be helpful? I am guessing if too tight it will be hard to put back. Thanks, Keith
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22099 |
Surely the pin that goes into that hole is worn out too ???
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4946 |
Doc , can that be bored , machined , drilled out and have a bushing installed ? And yes then have the other end built up .
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
It may need to be welded up some and then bored and then a bushing installed. All depends how bad it is.
Makes no sense but the pin didn't wear much at all. thanks
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9975 |
Not a problem.
The hole on our D-17 was in the same condition as the one in the photo. Over 20 years ago, I rebuilt it with Belzona 1111 (Super Metal) and a new bushing. Replaced the worn out pivot pin with new pivot pin. This tractor has a 500 loader. Most of the time, it is used to move round bales.
