D17 front pedestal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: D17 front pedestal
    Posted: 12 Apr 2010 at 1:15pm
When I removed the ft pedestal (narrow front) to pull my engine I noticed there is some play in the front axle in the tube. The I&T manual is not very good at describing how it's put together in there. If I remove the lower part of the housing for the narrow ft wheels, am I going to need to align the rack for the power steering cylinder? Are there bearings that maybe need a shim removed to take up the play, or a worn bushing?
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 4:17pm
just did one on my tractor.. end play cause was worn out bearings..I just  made sure that wheel was centered.. i have all the timken bearing and seal numbers if you need them just pm me
This page was generated in 0.622 seconds.
