D17 front loader rams |
Sblaber
Topic: D17 front loader ramsPosted: 08 Jul 2021 at 1:35pm |
Series 1 d17 with dreaded trip bucket (but I love my 65 yr faithful old girl).
Issue is 42" x 1.5" rod squirting hyd fluid. Is there/what part number where can I acquire to get her up and doing what she does. Thx steve |
Joined: 11 Sep 2009 Location: illinois Points: 89171 |
Posted: 08 Jul 2021 at 1:53pm |
I dont know what loader you have or who made the cylinders. I can tell you that "most" of the cylinders use a CHEVRON ( VEE) type packing with an adjustable nut on top to tighten. You should be able to see the "NUT" or hex at the end of the cylinder tube.
Here is a discussion about packing and buying aftermarket instead of from AGCO.. You need to measure the ID and OD of the packing you needd if you want to go that way. Pictures go with the discussion.. lots of good info. https://www.allischalmers.com/forum/d12-2-hyd-cyl-packing-w-gland-nut_topic175783_post1484838.html?KW=vee#1484838 Edited by steve(ill) - 08 Jul 2021 at 1:56pm |
