D17 Front Bolster worn out
New Allis Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Fan Quote  Post ReplyReply Direct Link To This Post Topic: D17 Front Bolster worn out
    Posted: 14 Mar 2023 at 7:08pm
Hello ,looking for a good condition front bolster to fix my D17 ,Front pivot pin area is wire thru . Does anyone have one for sale ? It is a wide front series 4 . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:34pm
Post a pic of the worn area. It might can be repaired. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Fan Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:37pm
Ok Tracy ,it is the worst I have seen ,I can weld it up
And send to a machine shop ,but I’m wondering if anyone has a good one . I’ll post pics tmrw .
Thanks
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:39pm
Doubtful that you will find one as nice as a good machine shop fix. They are ALL 60 years old !!
Edited by DrAllis - 14 Mar 2023 at 8:40pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:44pm
I repaired the pivot in my D-17 over 25 years ago.  Used Belzona 1111 Super Metal to fill the void surrounding the pivot bushing.  Welded  a new pivot pin to the wide front end.
We use the D-17 for field work and use the 500 loader for all sorts of heavy work.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 4:40pm
x2!
Post Options Post Options   Thanks (0) Thanks(0)   Quote New Allis Fan Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 7:22am
Update : I actually found one in good condition ,someone had drilled and tapped it for a grease fitting ,I’m going to install a new bushing but the casting has not been touched . Lucky find ! Thanks for the replies.
