D-17 Final Drive oil change. |
KY D-17 ![]() Bronze Level ![]() Joined: 07 Jan 2024 Location: Onton, KY Points: 50 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2025 at 9:37am |
How do you drain the oil form the final drive to change it on a D-17 Series IV? KY D-17
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8456 |
remove the pan. might be easier if wheel is shifted out
Do you need new gaskets?
Likely. Won't know till dissasembly
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2256 |
I replaced the oil in the final drives on my D-17 a few years ago. Dropped the pans and made new gaskets. I did have the wheels moved out. I chose to fill the pans before installing them but you could fill thru the fill plug as well. ![]() Not a big job. ![]() ![]() Edited by Brian G. NY - 05 Apr 2025 at 11:00am |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5118 |
I changed mine 2 years ago, according to the smell it was the original oil. Really stunk. New gaskets and put a clear hose attached to the oil bottle and refilled through the filler hole until it was to that level.
Edited by AC720Man - 06 Apr 2025 at 6:47am |
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2150 |
I did what Bryan did on my WD a few years back. Just make sure if you prefill the pan that you don't overdo it because the bull gear displaces a lot of oil in that pan as you put the pan back into place!
Thank You
I put the recommended 1-1/4 Qts in each side before installing the pans.
Thank You. My book says 1 qt. I will be sure and check it.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1034 |
You have a far steadier hand than I sir!
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3957 |
I have always put the grease in the pan first also. don't think I've even spilled one, somehow.
