D17 f gaskets
Doobletango View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Topic: D17 f gaskets
    Posted: 22 Sep 2020 at 6:35pm
So I have these f gaskets in my gasket set. I read on another post to use them only if the main cap is shimmed. I had nothing under my main cap upon disassembly.
The post also said to apply a small bead of silicone under the main cap if the cap was not shimmed. Why would I do this to the rear but not the front also? These AC engines are really testing my engine knowledge, but I want to make sure that I have this thing together right the first time.
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:45pm
The front main cap is INSIDE the engine. The rear cap is exposed. I never use the F gaskets and don't really care what others do or don't do. I use oil resist RTV where the F gaskets go and under the main cap a little bit and on the ends of the rear seal tips. Rear seal glued in place (bottom of groove) with 3M8001 top and bottom. Thinly wipe grease on the inside of the rear seal for lube keeping away from the split points.  Install the pan gasket parts correctly !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 6:55pm
I see what you’re saying now. *smh*
   Is there a specific torque on the timing cover bolts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 7:05pm
Just whatever a bolt that size should be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doobletango Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 7:13pm
Thanks! Just making sure.
