d17 engine update
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: d17 engine update
    Posted: 21 Aug 2011 at 1:20pm
I asked about replacing my series IV d17 "knocking" gas engine with a 262 gas and the consensus was to keep the present engine.  However, if I'm going to overhaul it what can I do to increase the horsepower?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 2:02pm
as much as your pocket book or wife will let you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 2:27pm
Overhaul would include new pistons, sleeves and rings. Get an OEM AGCO set from a 170 or 175 which is the same bore and higher compression and will not be hard on gasoline use as compared to overbore kits.
