D17 engine swap
rhoag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhoag Quote  Post ReplyReply Direct Link To This Post Topic: D17 engine swap
    Posted: 21 May 2022 at 5:39pm
Could someone tell me if a D17 series 4 engine can be used in a D17 series 1 tractor?
    Thank You
    Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 8:10pm
Your choke linkage will be different or use your old carburetor. Your power steering pump would have to be grafted onto the newer engine, if you have power steering. Must use your old or reman clutch and pressure plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhoag Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 1:48am
First Thank You for that information.
When you say power steering pump would have to be grafted onto the newer engine
do you mean that i would just move the pump from the old engine to the new engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 6:13am
Old power steering pump has to be removed from the old engine, mounted and gear lash set on the new engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhoag Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 1:32pm
Would all the parts from the old engine fit the new engine .I found a series 4 short block
i can buy that's been rebuilt.  parts from the old engine like head,oil pan ,oil pump ,etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 3:35pm
Everything should interchange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhoag Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 4:07pm
ok thank you.
the engine i have has crankshaft number 229022 . Do you know if the series 4 would have
the same crankshaft .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 6:15pm
A series 4 will be a different p/n but it directly interchanges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhoag Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 7:19pm
Thank You the information you have given me . It's much appreciated.
    Rob
