D17 engine builds |
AintCheatnAintTryn ![]() Bronze Level ![]() ![]() Joined: 27 Feb 2025 Location: pennsylvania Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Aug 2025 at 2:00pm |
My pulls for the year are all wrapped up, all said and done I think I did pretty good with a bone stock 17, that said my motor definitely needs a rebuild. Ended up getting the green light to build it as I want/can afford. I've been on a few different forums and have some ideas but I'd like to hear what builds everyone else has done and what HP was got. I'll be building for heavy weight, 7k and above, I believe up to 18k, dead sled, clay track. I'll be pulling transfer as well but I care more about the dead sled.
who needs practical experience when you have a computer, a calculator and ideas? me.. dumb ideas get expensive fast.
A few people have mentioned that d17s are no good for classes above 7000 pounds, while I won't say that they are all wrong, my family and I have had vastly different results. Every year two of my cousins pull d17s in the 9000 and unlimited classes and do very well, last month my brother even out pulled both of them on a d17 diesel weighting in at 16820. More farmall 400s and 450s get winched onto trailers and Allis's. (5 farmall, 0 allis). I can see about providing pictures and videos if anyone is skeptical.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5020 |
You can pull any class you like for a while....
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3526 |
Yes, sir, I painfully would like to see your D17 with 11,000 of weights slung on it.
https://imgur.com/a/8ed1wgw
I hope imgur is okay. I'll be adding more pictures and videos later in the day. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21866 |
It's been 30 years ago, but I saw an 88 Oliver break in half at a tractor pull. He only weighed 10,000 lbs, not 16,000. Whomever your insurance company is for these events must not ever show up to watch what they are liable for. And if they have watched what's going on, are totally ignorant of what could possibly happen.
I can't imagine any pull sponsor allowing something like this to happen. I hate to be rude, but even this is absolutely dangerous (and a few other things).
I don't mean to come across as rude in this comment or whole thread. I would like to make a few comments here. 1. I had asked about motor builds and suggestions. Dr Allis, you have recommend 100hp builds for d17s in 5000lb classes, with the bore and stroke you can get out of a 17 I can only assume these are high rpm motors running high compression. I haven't seen enough comments by WF owner to nitpick anything he specifically said by other things I've seen him recommend to people. Both of you have mentioned that pulling that heavy is dangerous and whatever "a few other things" implies and while I can't entirely disagree with the statement, we are running STOCK tractors, low compression and rpm, max of 2mph when pulling that heavy. There absolutely is a natural risk with any style of pulling but hot stock and modified tractors are far more likely to grenade a motor and send shrapnel. as of thus far the worst failure we've I've seen was a broken axel housing, while there is a risk of a tire hitting the driver in that event. Fortunately everyone that pulls in the heavy weight class has though of this in at least some aspect, wheely bars, weight brackets, and supports are in positions to catch the tractor and protect the driver. Please, if there is a concern with how our pulls are handled, wether it be in regards to the tractor we'll being or the drivers safety I would be more than happy to shed some light on how things are done at our pulls. Questions comments and concerns are welcome but it would be appreciated if it were more than just saying that it's dangerous and "a few other things"
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87723 |
David, could you explain the rational for using a D17 in a 16,000 pound class with higher HP... I would think you would be worried about the final drives, trans, clutch, besides the engine... Why would one not use a D19 or D21, etc ??
are youi limited to engine displacement or ??? Not arguing, i just dont understand.. Edited by steve(ill) - 25 Aug 2025 at 6:59pm |
My engine builds for a gas D-17 are 400 cubes and 100+ HP at 2000 RPM. Not high speed. The guy that broke the Oliver in two pieces never expected anything like that to happen either. He was 100 HP back in those days. He fixed the tractor and never weighed it down that heavy ever again. I know for a fact Farmall M's would break rear axles when they had a mounted corn picker on them. It was a common failure. So best of luck to your pulling group and hope nothing ever happens.
Edited by DrAllis - 25 Aug 2025 at 8:40pm |
Were always worried about breaking some components. It really boils down to we just want to, things will wear out and break but so far neither I or any of my cousins or uncles that pull Allis have seen a d17 break when pulling. I couldn't tell you exact weights of tractor but offer the past 8 years there's been a d17 loaded to 14k-17k for our "king of the mountain" class.
The reason for the tractor model being a d17 and not a 19 or 21 id because the club I'm has a year limit, 1960 and older. The rules are pretty relaxed and basically boil down to "the tractor must appear stock". No motor swaps that weren't available at the time, to turbos, no injection unless a factory diesel motor. What you do inside the block and transmission is essentially up to you. That's the thought process behind wanting to build a 17. In my experience (4 years) and my uncle's who got me into this (12 years). A d17, even a series 1 has yet to have any issues that weren't clutch or motor related. I know it can and will happen eventually but I'll cross that bridge down the line, I just want to know what it'll do before that. So far it's weighing in at just shy of 16k and pulling 21k. Thank you for the question, Dave |
Dr Allis, a few things id like to say here, admittedly I don't know much about farmalls so I'm going to take your word on that information about the corn pickers, I know of one super M that runs a corn picker on occasion but I'm not sure if super M's have different axles or housing than a regular M. I will say though that I've seen a few M's and 400s crack hubs when pulling dead sled.
In regards to the Oliver 88, I could be wrong, I don't know Oliver's at all but I believe they have a lighter, thinner axel housing and axel. I've heard of 77s and I think super 77s breaking while plowing which is the only reason I didn't get one myself. I would love to know what you did to get a d17 motor to 400 cubes and 100+ HP at only 2000rpm if you're willing to share the info and possibly bounce back ideas I think that would be great. I joined this form to learn but I'd doesn't seem like him I pull is liked by the forum. I'm certainly not trying to start any arguments here but I hope you can understand how someone would get frustrated in my shoes. I completely understand that as so.e point I will break my tractor but that's part of the game for me, finding the weak link and making it stronger, personal experience and experience from those I know right now tell me it's the motor. I'll be watching out for the final drives as you've cautioned before but I'm playing this as it goes. Thank you, Dave |
T Hunter ![]() Bronze Level ![]() Joined: 07 Jul 2019 Location: Kansas Points: 73 |
Aintcheatn.....I don't participate regularly on here but have noticed a few things.
First off I was really looking forward to seeing the results of your post. I am sorry but in my eyes it " got hijacked ". If I were to break in a thread and ask an off color question or post something off subject I am sure I would be corrected /reprimanded. Second it is your business what you do to your tractor as far as modification or treat it. I see people leave them for dead, scrap them, even put engines in them that were never intended to be in them. Third I believe building a motor 2 times or more cube, 3 times the horse power and or exceeding designed rpm rating is no different than 2 or 3 times the wieght of ship wieght. Forth we all know the dangers of motor sports. I only hope common sence will prevail, from the promoters, operators, and even the spectators. (Especially to protect lives) I see people get criticism all the time on here, including myself. I only wish we could all just be happy that everyone on here has a common interest. From what I get told "maybe you could start a new thread" and leave your details out on weight so that you might get "non judged" information you are looking for. I been around orange all my life, and love antique pulling. Wish I knew more about it. Unfortunately its a tight lipped click. I even considered paying to have an high dollar motor build for a 1500 dollar tractor to attempt to be competitive. Unfortunately they turn me sour when I get the cold shoulder. In conclusion.... I just can't see a young person trying to learn and enjoy an old hobby get criticized....if there is positive comments on the subject of the title ....GREAT! If not just do what what I always receive....SILENCE! In conclusion... Sorry to raid your post, and I hope you get the info you are searching for. Enjoy your hobby. I wish you the best of luck! |
To duplicate another G-226 engine of that 390-400 cube size would cost maybe $10K ready to drop in. I'm thinking at least $6500 for the custom made pistons (to my specs), sleeves, bore the block, make a center main cap brace, grind the camshaft and a weld up stroker crankshaft. I'm sure there's someone out there who could build you an engine like this. I guess my struggle would be finding a crankshaft stroker guy. The one I used years ago has passed away.
Edited by DrAllis - 27 Aug 2025 at 8:29am |
As to negativity - my comment and question was due to a near fatality seeing a torque housing fail on a 180 that reared up and the front end hit the ground. The factory specs on a 180 as to max weight is 9500 # and yes that has a lot to do with ROPS specs. Those that have been into a D17/185 torque housing at the power director know it is thin. Then there is a big cut out for the inspection area. The one that failed, split the tractor and almost fatally crushed the driver between the steering wheel and seat as it bucked. The loader frame saved him. I enjoy motor sports and have helped many young guys hop up some tractors. Some things do scare me due to past experiences, pointing out a danger is not a personal attack, it is a love for the sport and participants.
Edited by tbran - 27 Aug 2025 at 9:16am |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3900 |
take a look at my budgit biuld i have about 6000 in cash laid out in what done it does run good
In my 50+ year career of working on A-C tractors, I have seen four tractors broken in half (180- two 185's and a 200) from loaders. They all broke in the torque tube. The stresses they were put under with a poorly attached loader took the castings beyond their capability. When Allis-Chalmers tested the new model D-17 at Nebraska Test in 1958, they had it weighing 9400 lbs with a driver. 7450 lbs on the rear wheels (wheel weights and fluid) and 1800 lbs on the narrow front end. A-C engineers were comfortable with this. The Nebraska test engineers were too or they would never have tested it. The lion's share of added weight was directly on the rear tires, not on the chassis. Really serious pulling tractors have tie bars from the rear axles to the side frames, to try and keep the chassis from spreading apart in the event of a chassis failure. Safety equipment and rules were made to try and keep someone from getting hurt. Sometimes the "rule" was made AFTER someone got hurt.
Thank you for explaining the danger there, you actually just confirmed that the torque tube is weak right there. When building the brackets for the diesel 17 we were thinking about weak points and where would be most likely to snap and that was the main concern. If you look at my profile on imgur and check out the heavyweight tractor you'll see a belly bar, it bolts onto the frame with 3 bolts per side and runs back all the way back to the snap coupler. The thought behind how it was designed was that in case the tractor does split it shouldn't be able to move much if at all.
I could be wrong in how the tractor will move if it does snap and where it could but that's part of why I'm on this forum, insite from people like you that could tell me where weak points are to I can properly reinforce those areas or build brackets so if/when something breaks it's in as safe a manner as possible. |
I can't post this, but it is why tie bars were implemented in 1989. Please watch, all of you pulling enthusiasts: Full Pull Flashback: Tomah, Wi. 1989 Larry Lundry takes a wild ride......
