D17 Diesel
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Topic: D17 Diesel
    Posted: 16 Aug 2017 at 12:04pm
I am wanting to pull. I have a Farmall 560 diesel that i can fix up. I want to pull farm class, at my age that will be fun. I pulled a AC series 4 a few years ago, but i traded it. If i got a D17 diesel can i turn the fuel up on that pump ? Pulling againt those farmall with TAs the power direct would be nice. D17 farm stock, what do you pullers say?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 9:36pm
Turning the pump up on these engines only results in more black smoke - not any more power.  Its hard to get much more than stock power from a 262 diesel engine.  I am not a puller, but that is what I have read before.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 12:07am
you would have more money in it then it's worth' still won't have enough cube's in motor.
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 5:44am
It should give a stock Farmall M a run for it money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 7:15am
Get the 560 or a gas D-17.  A "stock"  Farmall "M" ???  There is no such thing. They all have 400 or 450 pistons and sleeves in them after all these years. That's why they aren't 6 volts anymore.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 7:38am
Couple guys in my club running wd45 diesels that im sure are at least 262's.  they both do quite well and the motors dont really smoke until they are loaded hard.  Natpa Div 2&3.  Div3 guy pulls lighter and the Div2 tractor pulls 4500 up to 6000 running 16x9 34 tires.  he will almost always spin out,  but sometimes does power out in the 6000.  Id like to know what they did and how they hold them together.  guess i need to ask.  but they are no match for the M's with 6.5+ inch stroke
Edited by CAL(KS) - 17 Aug 2017 at 7:39am
This page was generated in 0.211 seconds.
