D17 Diesel Won't Start!
Toneman1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toneman1 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Diesel Won't Start!
    Posted: 27 Jun 2011 at 12:51pm
Need a starting point here please.  My D17 D Series IV ran perfectly the last time I used it to mow.  Yesterday I was going to mow again and it will not start.  Turns over just fine, It just will not fire up.  I figured the first place to start was the fuel tank and work my way to the injector pump.  I would rather not resort to starting fluid with the direct injection type as I have observed many times on this forum.
Also, where can I find the proper fule filters as I figure they will need changing in this process as well.
Don't worry about the mule going blind, just load the wagon.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 1:13pm
Is your shot off lever in the correct position? Seen it happen more than once.  Start at injector pump with loosening the infeed line. See what kind of flow you got, then work your way back to the tank.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 1:49pm
Do you get smoke?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toneman1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 2:51pm
Shut off lever moves the arm on the pump as it should (to the best of my knowledge).  And there is absolutely no smoke from the exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 3:20pm
Pump is not turning on,check linkage.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 3:34pm
I agree with Bob something has happened to pump. If it was running ok last time and you pulled shut off to stop it, And now it won't ! With no smoke something happened inside or its stuck in off position? I forget how its made -works inside, I'm sure one of the pump experts will tell you.
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 4:10pm
If it has set very long it probably has a stuck metering valve in the fuel housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2011 at 7:28pm
Run position is to the rear on the shut off lever. Napa has the filters, or call Sandy Lake. No smoke says no fuel. They will run maybe a minute with the fuel shut off before it will die. Usually if the governor ring is disintigrating, it will run maybe 10 minutes before it quits. Little bits of governor ring material clog the return line. I would be wondering if the pump is turning. Take the cover off the timing window and crank the engine. You might need someone to crank the engine while you watch. If nothing turns, it's probably twisted the pump drive shaft indicating a seized pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toneman1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 4:32pm
Thanks for pointing me in some direction that makes more sense.  I really appreciate the help guys.  I will let you know what I find.
q4016lanz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 8:56pm
sounds like the pump drive to me i have had it hapen to one of my tractors can you get the roosa-master pump drives over there i need one for a IH 660d i by a lot of my parts from USA cheers john
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2011 at 9:36pm
As mentioned before, could be in the pump.
Had the same thing happen to a D-19 diesel, Wouldn't start all the sudden.
Ended up being a stuck valve in the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 7:28am
Welcome John. If you were here in the middle of the U.S., I'd say try Colfax Tractor Parts in Colfax Ia. They ship stuff all over as far as I know. 1 800 284 3001 or 515 674 3001. Find them on the web at colfaxtractorparts.com.
Post Options Post Options   Thanks (0) Thanks(0)   Quote q4016lanz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2011 at 8:18am
Thanks Brian I look them up on the net they have a lot of parts I will ring them tomorow it would be good to get the old 660d going again it is a good tractor in the tractor pulls
