d17 diesel throttle shaft seal replacement advice
elalr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Topic: d17 diesel throttle shaft seal replacement advice
    Posted: 18 Mar 2012 at 8:41pm
tomorrow (if it doesnt rain) i am replacing my throttle shaft seals. anyone have any advice to give me, or things to watch for? can i leave it on the tractor or does it have to come off? i cant screw this thing up! PLEASE HELP!!! thanks in advance. series one d17 diesel, roosa master dgf pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 8:53pm
by the way i found a john deere shop manual online and it had a roosa master pump dg series and it looks the same. am i wrong?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 7:13am
Don't loose the shut off tab into governer. Not sure if inside shaft will come out because of clearance between pump and block.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2012 at 7:36am
thanks for the advice. i hope this goes well
Post Options Post Options   Thanks (0) Thanks(0)   Quote elalr Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 5:55pm
got it done! suprisingly easy! the john deere injector pump manual was the same and the shut off shaft on the back side came out easily without removing the pump. if anyone needs the manual or help on the same job, id be happy to give advice.
This page was generated in 0.039 seconds.
