D17 diesel Tach drive
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel Tach drive
    Posted: 27 Feb 2023 at 2:00pm
Not sure why I am unable to remove my tachometer cable from the drive unit on my diesel? Unscrew the round cable retainer and pull the cable out? It’s in there tight, is there something else I need to unscrew or remove? Tach works fine I just want to install a new cable.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 3:54pm
Put a set of channel locks on it.  Loosen the collar and wiggle the cable until it works loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2023 at 8:04pm
Ok thanks, just wanted to make sure I wasn’t missing something
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 9:38pm
Well tried that, and no go. It seams like there is something that is keeping it from coming out. The drive is different then what is one my XT, D15
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 11:41pm
AC720Man
Perhaps this info will help you......
I discovered the drive end of the old cable, broken off and still lodged in the hole, when I was installing a New Tach Cable.  The previous owner had left the Tach Cable/Sheath in place once the Tachometer stopped working. I was able to remove the Cable Retainer and the Sheath, but could not get the new Cable into the hole.  It took a while to figure out what was going on!!!
 I could see the drive gear on the top of the oil pump shaft turning, with the broken cable end sitting inside the hole.   I was able to extract the broken cable end from the hole, with very fine wires clamping either side of the broken cable end and gently pulling it out of the hole.  It fit loose in the hole.  A magnet might have pulled it out, bit I did not have one handy
Is it possible your cable is wedged in the hole, preventing extraction?  It should be loose.  Perhaps it is all twisted up and binding preventing extraction
Does your cable turn when the engine is operating?  Or is it broken off somewhere down there inside the Sheath or in the top of the oil pump housing?
Your next step would probable be to start cutting away the Sheath so you can get some WD-40 down the hole to start loosening up the cable for extraction
As I recall, this area is in behind the fuel filters, so not much room...........
As an aside.........I also discovered the old Tach would not move when I tried to manually turn with the new cable (probably what broke the old cable in the first place)
So I took the Tach apart, cleaned and oiled the moving parts, and it works real well now.
Please keep us posted on your efforts
Good luck
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2023 at 11:45pm
AC720Man
Forgot to mention, my post above was for my D17 III Diesel (IV has same setup)
Jasonw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 6:17am
It could be the steel end of the cable is rusted in the shaft that drives the cable. I had to remove the entire tach drive adaptor assembly from the engine block and drive the end of the cable out with a pin punch. Remove the screw that holds the drive adaptor to the engine and the whole assembly should come out. There is a small shear/drive pin you will have to remove to get drive coupling off of the end shaft. From there you can try removing the cable end though the slot cut in the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 8:26pm
The cable still functions and turns the tach. So, it isn’t broken. I have soaked it several times and it’s obviously rusted in place. Jason contacted me this afternoon and he had the same issue on his series III. He took the 1/4” bolt retaining bolt out, loosed the small clamp bolt, turned the assembly and removed it from the engine. His was rusted in place also. So I will try that in the next few days. Thanks for all the suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:44pm
Jason thanks for the phone call and pictures that you texted me. You were exactly correct and I successfully removed the drive and disassembled it in order to get the cable removed from years of rust. Appears to be the original cable. Cleaned and lubricated the drive. Haim at Star Speedometer is making me a new factory correct cable.
Thanks Jason!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2023 at 7:54pm
Forgot to take a picture of it cleaned up before I reassembled it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 11:02am
AC720Man
Congratulations. Excellent pics.  That cable was not going to fall out of the slot!!
Great to see members take the time to get their equipment back to original
Thanks for posting your project
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2023 at 9:10pm
Always a good feeling when something goes right and the problem is resolved. This D17 has had plenty of them lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 4:33am
Remember to apply never sieze compound on re-assembly!. After removing 1, I figgered out that this was a job for Kroil, then vice grips with a slide hammer attached..Wink
If you don't have room for a full sized slide hammer, there is a smaller version, available, too!
Edited by DiyDave - 06 Mar 2023 at 4:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jasonw Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 7:16am
You're welcome Robbie! Glad it all worked out for you. It's hard to imagine they get rusted like that being almost inside of the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2023 at 8:30am
I’m a huge fan of Kroil but I soaked it several times since I had my Tach rebuilt and it didn’t work. May be the first time Kroil didn’t creep to get it loose. After I disassembled I could see why. I use never seize in most applications but I didn’t use never seize because it is designed to draw engine oil up the tube via the spiral design. Since I cleaned it well it should work as designed.
RCrabtr2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RCrabtr2 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 8:52am
Good morning,  I have a 1961, Series II, D17 D, SN: 36471, Does the tach cable also connect behind the fuel filters?  I have (what I believe are all the manuals), I have scoured the web and your post is literally the ONLY ONE, that mentions a possible location for it.  Thank you in advance for any help you, or the other amazing folks here may be able to provide!
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 9:36am
Yes, right where you’re thinking. See the pic, cable is attached
Post Options Post Options   Thanks (0) Thanks(0)   Quote RCrabtr2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 10:28am
THANK YOU!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 10:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 10:16pm
This is mine from 2 years ago, had to remove the entire drive assembly to get it apart. As you can see it was full of grime from 66 years of use.
