D17 diesel series 1 |
dan1714 ![]() Bronze Level ![]() Joined: 20 Nov 2010 Location: oxford, iowa Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 29 May 2011 at 7:14pm |
I changed oil in the tractor a while back and know it leaks out the side of the filter. There is only one gasket on it and its tight. I have the same oil filter I have used for 7 years on it. I also tried a new gasket and it did the same thing. Any help would be helpfull thanks.
You don't have something under the gasket between it and the filter base do you?
no I cleaned it off
Kraig (WI) ![]() Silver Level ![]() ![]() Joined: 19 Sep 2009 Location: Fairchild, WI Points: 163 |
Same thing happened to me. I cut another gasket out of gasket material and now have two gaskets in there and it works fine. Kraig (WI)
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72 |
jasperalden ![]() Bronze Level ![]() ![]() Joined: 30 May 2011 Location: Cambridge, MN Points: 1 |
I'm new to AC tractors, I bought a D-17 from a relative. Does anybody know the approximate weight of one of these.
I haven't seen it, so all I know is that the motor is stuck and it's complete. Wide front or narrow front, I'm not sure. The price was great. I have a 7,000 LB GVW tandem trailer. I'm hoping it will handle it. Any help is greatly appreciated. I will be restoring it. Thanks Jeff
BCPuller ![]() Bronze Level ![]() ![]() Joined: 30 Aug 2010 Location: Indiana Points: 34 |
We had a problem like that once and the filter was bad. check that out
somebody ![]() Silver Level ![]() ![]() Joined: 03 Jun 2010 Location: western NC Points: 111 |
I think about 5200 lbs.
Tedin NE-OH ![]() Silver Level ![]() Joined: 30 Mar 2011 Location: OH Points: 177 |
Shipping weight of gas tractor 5300 lbs. add for loaded tires
A 7000lb trailer would be pretty much maxed out. If the trailer has car tires, you would want to switch to an actual trailer tire.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Series I has a cartritge type filter. I have seen problems like this before. Could be a damaged cartritge or trash from the old gasket still in the base. I replaced my filter base with one off a 19. They use a spin on filter.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I just had the same problem but thought it might be from the NOS filters that I am using. I finally let it set overnight in oil and I think the rubber swelled up a little and then when I tightened it down it sealed. I think I might put one from a D19 on it...it was a royal PITA! That little drain plug on the side was sure some bright idea, too....
ALLIS EXPRESS!
This year: |
