D17 crankshaft
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D17 crankshaft
    Posted: 13 Mar 2016 at 11:36am
What engine serial number did they go to larger main bearings?
www.awtractor.com
A&W TRACTOR 920-598-1287
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 2:36pm
All D-17's have the large main bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 2:45pm
It's funny, how when someone starts an untruth like that, how long it hangs on as a truth. That's why there is a W-226(WD-45) engine and a G-226(D-17/170/175/Gleaner E) engine. They are NOT the same engine assembly, and the main bearing diameter was the most notable change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 10:13pm
Thanks Guys, I will be sure to remember that.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 9:28am
Did the thrust main get moved from where it was on the W engine to a different journal when the G engine was produced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 10:09am
"W" was on the front main and "G" was on the center main.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 11:02am
Thanks Tom. I thought they did something like that.
This page was generated in 0.099 seconds.
