D17 Cam bearing
djake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djake Quote  Post ReplyReply Direct Link To This Post Topic: D17 Cam bearing
    Posted: 14 Jan 2020 at 4:21pm
Does anyone know if the cam bearings can be replaced on a D17 gas
without pulling the head off? I've got the oil pan off and the crank out.
Wondering if I only need to pull the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 5:23pm
Djake,
The engne is out on a stand upside down? I would think that the cam bearings could be changed with out removing the head. Remove rocker arm, and remove push rods. Then rotate the engine upside down so the tappets are down, Timing cover off. should be able to pull cam. then bearings. But I have never done this and folks like Mack, Dr Allis and Don(MO) would have better details. you might need to change the welsh plug at the back of the block for the cam. I had my machine shop install my cam bearings as the block was being worked on.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:09pm
Yes, remove cam, cam followers, and rear plug. Have a good bearing driver that fits bearings and start them in straight.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 8:52am
If the block is in the upright position, you have to pull the push rods and get the lifts up, and held up, in order to remove and replace the cam. So, the valve cover and rocker arms should come off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 9:03am
djake,
 Here is that big welsh plug at the back of the block, covering the rear cam bearing, Important not to block the oil hole in the block when installing this back bearing:
Cam out would look something like this:
cam installed:
Correct me if I am wrong but I believe the oil pump needs to be pulled. It is drive off the cam. Good time to service the oil pump too. Service manual describes the inspection of the oil pump. I made the mistake of not doing this and I pulled the engine again to tune it up.
Timing cover aligned and new crank seal installed:
Question for MACK. Are the cam followers you mention, what I called tappets which I should have called lifters?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 9:31pm
Lifters, cam followers are same thing. I would call the adjustable rocker arms the tappets.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 10:58am
Yes my mistake. Thanks MACK!
