D-17 Brakes |
Jeff Z. NY
Topic: D-17 BrakesPosted: 08 Mar 2010 at 7:54pm |
What are some methods some of you have done to remove pin on the brakes?
skipwelte
Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Posted: 09 Mar 2010 at 5:07pm |
Lots of heat with the blue wrench in the axle housing where the pin extends to the outside. the ones that arent to tight you can get a puller on the end. The real, real bad ones come out in short chunks, cut em with the blue wrench.
AndyinWI
Joined: 22 Sep 2009 Location: Blue Mounds Points: 416 |
Posted: 09 Mar 2010 at 6:08pm |
i have drilled and tapped the pin to 5/8 then used a short piece of pipe that was a little bigger diameter than the pin, 5/8 bolt, and a big washer, then stuck the bolt through the pipe and screwed the bolt into the pin, came right out with an impact wrench.
Hope this helps,
Andy
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 09 Mar 2010 at 7:30pm |
lots of blaster aN SOME HEAT ON REAR HSG. 1-574-342-4545
WE HAVE A PULLER DO NOT HURRY IT
