D17 brakes and drum replacement
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 brakes and drum replacement
    Posted: 06 Feb 2023 at 6:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:29pm
Had a really good day today. Finally got around to replacing the brakes and right side drum on my D17. Got along so well on the right side Mutt and I started the left side. Replaced left and right pinion seals, right side drum, installed new brake pads. Started the left side, new brake pads, have the drop housing off and also replacing the axle oil seal. Also replaced both housing pan gaskets, cleaned, followed by new oil. Having a issue getting the snap ring out so we called it a day. I’m pleased with our progress in 6 hours.
Edited by AC720Man - 06 Feb 2023 at 6:31pm
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 8:05pm
It’s surely a chore!
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 8:15pm
You got that right captain, but it went better than I anticipated.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 9:19pm
What snap ring are you trying to remove?                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 9:57pm
Axle gear snap ring. I’m letting the remaining oil drip out the housing overnight to get a better look at it. My factory manual says to remove it by going up through the bottom of the final drive housing. Getting a different pair of snap ring pliers tomorrow to get a better hold of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 10:03pm
I tried going in from the side were I removed the inner bearing cap. I removed the bolt, washer and shim, bearing cone. Just no room to remove it unless the bearing cup is removed.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 7:30am
It can try you. Use two big screwdrivers to pry it back on.                    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:17pm
Finished up around 1 today Mack. Took the axle to my local machine shop and had the bearing removed so I could replace the seal. Pressed the bearing back on, and reinstalled in the drop housing. Can’t tell how nice it is to have functional brakes. And I finally can lock my brakes without it drifting off. Easy to lock a brake left or right brake and spin it on a dime. Now, need to fix my power steering leak ugh. That repair will start next week.
Edited by AC720Man - 07 Feb 2023 at 6:19pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 8:20pm
Your pic suddenly made me feel jealous. Nice straight looking tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 9:55pm
Thanks JC, it’s a work in progress. She has some dings but I have completed a lot of repairs. It has the wrong shroud and grill on it due to something coming off of the loader and damaging it. I purchased the tractor without the loader. I have the correct shroud and grill. It’s a 1959 3 bar grill.
Edited by AC720Man - 07 Feb 2023 at 9:58pm
This page was generated in 0.088 seconds.
