D-15D Tach
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Topic: D-15D Tach
    Posted: 01 May 2012 at 7:53pm
Did any D-15 Diesels have tachs? If so how were they driven? Thanks Gary IN
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 8:26pm
There is a plug installed in the block above the plate for an external fuel pump. It looks like a spot for a distributor in a gas block. Remove the plug and there is an addapter that slide into that machined hole that is driven by the oil pump gear. I'll walk out and get a pic and be right back.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 9:15pm
Hope this shows up.
I may have another drive if your interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 10:55pm
Looks almost identical to a D17D tach drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 11:16pm
I guess it should as the 15"s 175 CI engine is a 262 w/ less 2 cylinders. Both engines are Buda Diesels.
Also if you are looking for a tach setup for a Diesel you'll need a Diesel tach as they are driven the opposite direction a gas engine is.
BTW Brian, I love your signature line. It's like anything is possible in a world where some men can create their own rules...........
Edited by D-17_Dave - 01 May 2012 at 11:19pm
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 7:22am
D15D tach is NLA, you would have to have yours rebuilt.....been there, done that......
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 12:13pm
Are the 15 tachs smaller than 17 tachs? I never looked at mine close enough to notice a difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 2:37pm
Must be a different face???? When I redid my 15D, a looked in the AGCO parts book and the 15D tach is different than the 17D series I-IV and also the 19D(part numbers are different)
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 8:51pm
I guess the question would be does the D15D turn the same max engine speed as a D17D? If the gearing was the same, a D17D tach ought to work. I'm 98 44/100% sure the main difference in a diesel vs a gas tach is they turn opposite directions. If he has to have his 15 tach repaired, I've heard that Metro Speedometer in Independence MO is good at restoring and calibrating old tractor tachs.
Thanks Dave. I joined a fraternity a while back and I can see a real difference in the values of the older guys vs many younger people today. Some stuff that is pretty common today just was absolutely a non option a generation ago. I spotted that quote on another site and when I think about it and compare it to history, along with some of my past life experiences, I believe it to be very true.
