d-1511 hydrualics
john n/il. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Topic: d-1511 hydrualics
    Posted: 07 Dec 2009 at 9:07pm
i want to use the 15 to split logs ,the 3point  splitter has a dual acting  ram ,but my 15 only has 1 hyd. outlet . i need  two ,what can i do short of spending to much just to get it to work.thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 10:29pm
use a different tractor.  Your 15 has a slow pump that only delivers 1.5 gpm (at a much higher pressure than average).  It would SLOWLY move the cylinder and not return it.  Unfortunately AC was a little slow bringing live hydraulics to their tractors in the 60s.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:54am
John
I don't know how much the D 15II pumps but like said it would not take a bunch to do that teeny weeny hyd cylinder in there compared to a big butt ram on a splitter.
Don't give up though, start searching for a pto driven pump and tank.  you can split in style then.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:46am
Best bet is a front mounted pump or PTO pump. You may also want to look at the double acting 12 volt hydraulic pumps. Put one on my D14 to run the 2-way cylinder on the snow blower chute and am pleased. Was less $$ than a pump, tank, valves, fittings and hoses to add a mechanical pump. Do a search on ebay for 12 volt hydraulic pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:52pm
greg if your on ,i have a front pump already that runs my loader will this pump work for the splitter
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:02pm
  that is what we run ours with  works good or excellent
Post Options Post Options   Thanks (0) Thanks(0)   Quote john n/il. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:06pm
hello norm . how do you hook it up .do you unhook two hoses and then put your splitter hoses on .dont you have to hold down on the loader levers to get the ram to work
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:07pm
John I had a CA with a front pump and loader.  Someone had put quick disconnects on one of the valves so that they could unhook the loader lines and connect in the splitter lines. They drilled a hole in the lever and made a linkage that bolted to it and ran back to the splitter and hooked to a lever on the splitter. The splitter also had a snap coupler hookup so that they could lift it up to move it.  I no longer have the CA, but have the splitter, it is well made.
