D15 Water pump
KYrod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Topic: D15 Water pump
    Posted: 10 Sep 2020 at 5:09pm
I recently got this tractor running and now find that it's leaking around the water pump.  Is this likely to be a gasket failure or what?
Just drained new radiator and preparing to remove it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2020 at 5:32pm
Likely to be a gasket failure ?? Nope. The shaft seal is more likely the problem. Time for a reman water pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KYrod Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2020 at 8:36pm
Any recommendations on a supplier???
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2020 at 5:28am
Got mine from Sandy lake . HTH
