D15 w/shuttle & 415 loader
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D15 w/shuttle & 415 loader
    Posted: 29 May 2022 at 1:16pm
Tractor has been gone through front to back and shuttle clutch gears installed. Rebuilt engine, rebuilt transmission, rebuilt seat suspension, new clutch, new brakes, new gauges, new seat, new ft tires, new battery, new muffler. New brakes. Resealed front steering gearbox, rebuilt power steering ram, new power steering lines, LED front lights, rebuilt distributor, rebuilt alternator, new wiring. Hyd filter was added. Factory 3 point hitch. Factory style foot throttle. Tractor comes with 6 month warranty.
Loader is fully hydraulic, powered by front hyd pump. 5ft wide bucket. Loader is in good shape, no warranty on loader.
Tractor is 44hp gas, 4 gears with forward & reverse in each gear. Shuttle clutch can change from forward to reverse without changing gear. Has live PTO with shuttle clutch lever in neutral. PTO turns 780rpm instead of 540rpm because shuttle clutch is installed. Ideal medium size loader tractor. Tractor can be serviced at local Allis-Chalmers dealer in Cecil, WI if staying local.
I used this tractor all winter for plowing snow, I estimate the time savings was 50% over my 170 non-shuttle clutch tractor.
$8500 for tractor with 415 loader.
Edited by Alex09(WI) - 29 May 2022 at 1:17pm
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2022 at 2:28pm
bump
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 8:25pm
Sale pending
www.awtractor.com
