D15 Starter
smtrull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smtrull Quote  Post ReplyReply Direct Link To This Post Topic: D15 Starter
    Posted: 04 Dec 2010 at 6:20pm
I'm trying to install a rebuilt D15 starter. It appears the new starter drive is extended out but will not retract. For some reason the starter drive does not want to retract and prevents the starer from sliding all the way into the tractor housing. Anyone have any suggestions?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 6:32pm
I'll add my thoughts; Have/did you compare the original starter to the rebuilt unit? Were they exactly the same? Bench test the starter for proper operation, just maybe the drive is NG.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 6:56pm
Some people don't realize there are starter drives that are backwards. The gear is away from the motor and advances toward the motor when you hit the juice. My G is that way.
Try putting juice to the starter and see if the drive advances backward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smtrull Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:04pm
I had the starter rebuilt at one of our local tractor repair centers that we have used for years. The new parts look exactly like all of the new parts I have researched on the web for this particular model. Just thought I might be overlooking something on the installation. I did bench test it and it is getting power the starter drive just doesn't seem to retract it always remains extented.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smtrull Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:05pm
The drive doesn't move at all when I add power to it.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:06pm
  the new drives are different you are not supposed to finger to see if it works!!!!!!
  if y ou can get it installed the motor  will turn it back  been there done that
 if you can turn it backwards as fast as the motor does it will go back an be ok
 takes the rust off y ou r thinking cap  like I SAID BEEN THERE DONE THAT
  HAD SOME CUSTOMERS DO THE SAMETHING HAD TO EDUCATE THEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:08pm
  SORRY YOU CAN CALL 1-574-342-4545 WILL TRY TO EXPLAIN ON PHONE   NOT THE COMPUTER
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 7:56pm
The starter on my D14 only "disengages" when the engine fires up and goes faster than the starter. Had a problem with it and needed to replace the insulating bushing on the bat lead...and running the starter drive on the wire brush on my grinder to disengage it before installing it again. Really frustrating until I got it figured out, but running the starter drive on the wire wheel really did the trick.
This page was generated in 0.075 seconds.
