D15 series II
Jon NW Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon NW Iowa Quote  Post ReplyReply Direct Link To This Post Topic: D15 series II
    Posted: 25 Apr 2018 at 9:33pm
Looked at one today. Nice tractor. Question is do the series II have the newer hydraulics like the series IV D17?
It has the factory 3 point.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2018 at 9:34pm
No,    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 1:13am
If you really plan on using the 3pt for any HD use, opt for the D17IV. Any 3pt on an Allis tractor smaller than the D17IV is very poorly designed and the mounting bolts are prone to working loose and ruining the castings at the mounting holes. For the smaller tractors a Snap-Coupler and factory 3pt adapter is a much more durable option if a 3pt is absolutely necessary.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 6:53am
We had a D-15 series 2 with factory 3ph and never had a problem with it, ran it for 17 years before dad sold the farm.  Baled a bunch of hay with that tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 9:15am
If you must have the "live" hydraulics like a D-17 IV, a similar system can be built to go on that tractor with a front pump or a pump custom made to fit underneath the hood. It can be done. Only takes $$$$$.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 11:03am
Yes, that was a nice retrofit, Doc!
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 11:06am
Even with a front drive pump from a 400 loader, a protection guard can be built around it. It will only protrude 6 inches in front of the grille.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2018 at 8:57pm
Have one sitting in the driveway that happened to. Gonna swap in a new trans this summer.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 7:28pm
I don't know how bad your lift arm housing hitch mount holes are, or the transmission hitch housing holes. I'm pretty sure there'd be a way to fabricate a brace to weld or attach the 3-point hitch pull frame forward to two of the snap coupler spring mount holes, giving you a total of six 3/4" bolts for the 3 point to pull from. This would see to it that nothing like that could/would ever happen again. Gr8 bolts torqued very TIGHT and Loctite on the bolt threads would be my preferred assembly method....
This page was generated in 0.081 seconds.
