D15 Series II /WD |
Steve A ![]() Silver Level ![]() ![]() Joined: 12 Apr 2012 Location: NLP Mi Points: 220 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Mar 2025 at 6:51am |
Kicking around the idea of replacing one of my WD's with a D15: I just put new tires and rims on two of the WD's. Will 28's fit on a D 15? Nothing wrong with the WD's but I like the idea of the lower tractor and the way it its set up.
THX! |
only AC orange ![]() Silver Level Access ![]() Joined: 06 Dec 2014 Location: Eastern Indiana Points: 485 |
Yes, the wheels will fit but there might be clearance problems - depends on wheel spacing, tire might rub on fender?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21234 |
If you ever plan on moldboard plowing, the snap-coupler bell will be (too) higher and lifting links on the plow too short. Also you will have to run a slower gear because your speed will be increased.
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1144 |
I traded a WD in on a D-15. Best decision I ever made!
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5100 |
What a step up!! You won’t regret it. D15 is a work horse for its size. Ours has pulled a 3 bottom Oliver plow for many years in 2nd HI range(4th). Great hydraulics and the Power Crator engine has plenty of low end torque.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8407 |
Steve A,
If you can get a D15 with power steering, that tractor would be your go to Allis! I really like our D14 even sans power steering. Good luck with your hunt. They are out there. Regards, Chris and Cheryl |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5814 |
And to take Sugarmakers comment one step farther, if your newly acquired D-15 happen to be a Ser,II, you would have the best of all. The Ser.II usually has Power Steering, it has a bigger Engine ( 160 vs 149 cu.in.) and a big advantage regarding your WD 28" tires, the Rear Fenders are mounted to a higher Fender Bracket. Allis raised the Fenders to allow for the larger 14.9 X 26 Tires. G |
Kenny L. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: NEIOWA Points: 1314 |
I've 14.9x28 tires on my ser II D-15, I can't remember if I spin the rim out or not but I think I did because I put chain on her. My is use as a loader tractor and has a shuttle shift which makes life a lot easier.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 2986 |
Measured the tires on a WD45 with 14.9 X 28 and the tires on a D15 14.9 X 26 the 28" tires were 1 inch larger outside diameter. Brand these days makes a big difference as to size also. Some 26" tires how very tall side walls too.
Same exact brand and model of tire I would expect 2 inches difference.
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1270 |
I have a couple of both. The D15 is nicer for pto work.
The WD is simply the king of torque. It will do the job at idle while the D15 needs a bit more. Riding all day? The D15 wins. That tiny ring and pinion in the D15 always makes me wonder about its limits. Drawbar load? The WD handles it better. |
Thank you all for the input. You've given me a pretty good comparison between the two and pointed out some things I was pondering about: Geometry of the snap coupler if I swapped tires and torque in particular. I've put a D series seat/frame on one of my WD's, moved the steering wheel a bit and that improved the ride and the working area.
A hand clutch versus a power director? Hands down no comparison, D15 is way better. I have both and would give away my WD before parting with the D15 series II.
