d15 series ii three point on series i d17
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: d15 series ii three point on series i d17
    Posted: 9 hours 6 minutes ago at 1:24pm
i have a d15 17278 sn at the shop to re pack some loader cylinders and was looking at the factory three point hitch  has any one tryed putting that setup on the d17
Edited by HudCo - 8 hours 56 minutes ago at 1:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 39 minutes ago at 2:51pm
Some things to consider: #1. A 4500 lb D-15 series 2 can destroy one of those category 1 hitches if used heavily. How long would it last on a 5500 lb D-17 ??   #2. I think the torsion bar and draft arms would bolt right on, but how do you intend to get the splined lift arms off the splined shaft??  You could remove the lift arm housing and remove both shafts with the lift arm still attached, I guess. It would mean removing the lift arm housing on both tractors to get it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 21 minutes ago at 9:09pm
The D10,D12 and D15 3 point hitches were too light!The mounting bolts were placed incorrectly. JMHO, Tracy
This page was generated in 0.039 seconds.
