D15 Series II runs terrible
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: D15 Series II runs terrible
    Posted: 18 May 2016 at 8:37pm
Good evening all,
Had trouble last year with our D15 running poor.  Random misfires, stumbling, etc.  Fuel delivery appears OK - no smoke, plenty of fuel to the carb.  Didn't tear it down though; because, I pulled the points, polished them with some 400 grit paper, and that cured it.  Ran like normal.
This spring, same deal again -  it got worse over the winter -  I said "the heck with it" and bought a set of the "house brand" points from TSC and put in it.  Ran great, again, for a little less than an hour.  This afternoon, I started it up, put the bushhog on, and after 2 minutes it was doing the same thing.  Limped to the shop.
Distributor cap is not cracked; rotor button is new, condenser and points are new, gapped to 0.020.  I burnished them just a little and it's running better but not well or "right".
Got a good set of plug wires on it.  Coil is "I-don't-know-how-old".  12V positive ground electrical system - factory.
What gives?  Just that TSC points are junk?  There's less than 45 minutes of run time on 'em.
Open to suggestions as far as replacement - upgrade.
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 8:51pm
Crap in the carb would be my first guess.  Take out the plug on the bottom and let some gas drain into a clean container.  If you see particles of stuff in there, it needs a good cleaning.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 9:24pm
Agreed with D series 4. I had this one time on my D-15. And then over time got worse. Definitely a head scratcher. Then boiled out the carburetor and it was a brand new tractor!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 9:44pm
I would agree with the fuel being a possibility.  I have had luck with just a bit of seafoam in the tank.  Only miracle fix I have ever seen work.
But, being that you have cleaned the points and it has made a difference tells me that you are having electrical problems.  First off, did you put on a new condenser with the points?
If not try that next.  Do you have another tractor to borrow a coil off of?  I was bit in the hind by our D17 a few years ago.  Was running a bit off, then ran worse and finally died, checked the spark, had spark but wouldnt run.  Changed plugs, fuel screen, cleaned carb, changed points and condenser, still nothing.  Borrowed a coil off a running D17, fired right off.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 9:47pm
Sounds like a coil problem to me.
After you have ran it a while and it starts to run bad, see if it has a bright blue snappy spark. If so, the coil is good If it is orangy yellow, a new coil is in order.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 9:53pm
Find the old condenser and put it back in.
If it runs better after filing points, resistor may be bad. Don't remember if it is  exterior or in coil.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 9:55pm
Thats where our D17 got me Creston, it had a bright blue spark, but wasnt enough to make a spark in the engine compressed cylinder! Go figure! lol
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2016 at 10:11pm
worked on the neighbors 17 series 4 was doing the same thing. if it would sit a few hours it would run fine,then it would run like crap to the point of shutting off.we replaced everything.come to find out there was more water in the gas than gas.drained everything out and put fresh gas in and it runs great.
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 6:39am
I had similar problems for a while till I figured out that a neighbor was stealing gas and replacing it with water....  Good Fences are a must.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 9:35am
IS the coil a 12V coil and labeled as such?  Often a 6V coil was used with an external resistor to drop it to 6V use.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 11:41am
There are a lot of good ideas to check listed. My thought would be more in line with Jim D. Make sure you have a internal resistor coil, and that is wired correctly according to system wired for positive or negative ground. If you are wired for positive ground the wire from the coil to distributor should be attached to the positive post of the coil. If it is a negative ground system, the wire to distributer would be on the negative side of the coil. As far as the resistor coil, an old mechanic diagnosed a similar problem for me. He said these point systems were designed to run on 6 volts. Run them on 12 volts and you will continue to burn the points. Also some of the older tractors had a ceramic resistor that reduced the voltage to the system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 11:53am
All D15s are 12 volt.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 12:12pm
I would just say check the wiring in general and the key switch.   My d17 gave me a hard time this spring I had to have someone look at it about the same story but it turned out to be a bad key switch
My d15 is getting rewired because the wiring is bad and spikes killing the points. So if the points look burned I would check that the wires are not just old an bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 3:42pm
My 15II is very sensitive to moisture, runs bad on rainy days or even high humidity days. Used to always reach for the Seafoam but this last year we have had plenty of humidity and rainy days so have had to drain the bowl sometimes 3x/day. She fires right off and runs well until more moisture collects. New points/plugs/condensor and wires two weeks ago and it is a different tractor; all stuff I bought nearly four years ago and had in the cabinet, and Echlin brand from NAPA.
Worth mentioning also is use of Lucas injector cleaner/fuel conditioner vs. Seafoam. Cleans just as well, dose not take much and only 8.75/bottle at Wally World. Started using it on 6.0 HD GMC and now use in gas engines for tractors/power equipment.
Very pleased with results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 4:55pm
Contact Steve at B&B and change it over to negative ground and get a Petronix electronic ignition with a Flamethrower coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 6:02pm
Don't forget to check the plastic insulator block that carries the wire from the coil to the points.  Also check that the points connection, to said block is not shorting out on the wall/floor of the distributor...
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 9:00pm
It has a new coil in it; I'll find the old one.
TSC ign. kit came with a new condenser.  It's got a red insulator in the end as opposed to the old black one (different design).
I have tried a jumper wire from the batt straight to the coil to rule out ignition switch.
Drained the carb - fuel was perfect.  I run 100% gas except when I know I can run a full tank thru in less than a month or so - try to limit E10 use in it.
I like the negative ground and electronic ignition idea, just want to rule everything else out.  Steve's plug wires are nice.
As far as that little plastic block in the side of the distributor - where can I get one of them dudes?  It appears to be OK, but I'm all about swapping everything minor.
Thanks for the suggestions... will keep looking.
Just to be on the safe side - check me on this:  to gap the points, I'm bumping the motor with the starter till the points are wide open - on top of the lobe in the distributor, then loosening the keeping screw, adjusting the brass screw until they lightly grab the 0.022 feeler gauge - the 0.024 won't go, the 0.022 will - this correct?  (They are supplied with a 0.020 gauge but the book says 0.022.)
Thanks again...
Edited by cbuttre835 - 19 May 2016 at 9:10pm
C w/ 3rd gear out
WD 45 wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 4:51am
Brillman co out of VA can get almost any dist part.  One other thing to check, dist bushings...  Grab the top of shaft, and watch the points, as you apply side pressure, to the rotor shaft...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 5:33am
You have me wondering if the surface the points ride on to generate the gap is warn down too much. Also check that the advance springs in the distrubitor are working.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 6:08am
Yes, check the distributor shaft bushings for play. This can cause havoc, a random, part time spark. So you see a spark and say "I got spark" and then focus on the fuel system. I can hear Loki laughing.
Check this out, we keep blaming the capacitor, rightly so?
capacitor construction
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 6:37am
I have a Studebaker that ended up needing a tow as the little wire inside the distributor (between the points and the plastic block) started grounding out. That one will drive you nuts if it happens.... I changed nearly everything before I figured it out. All it ended up being was the insulation around that wire cracked off and it started arcing there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 6:06pm
Never seen a points cam wear out.  Seen plenty of dist bushings WTFO...  A pertronix system also is much more forgiving of worn out dist bushings...
This page was generated in 0.067 seconds.
