D-15 Series I industrial tractor front rim |
JamesG
Joined: 27 Jul 2015 Location: NewEngland Points: 26 |
Topic: D-15 Series I industrial tractor front rimPosted: 17 Dec 2018 at 1:56pm |
I severely bent a front rim on my D-15 Series I Industrial tractor. I was looking at new aftermarket D-15 rims. Some say 'Not for use with front end loader'. Are all D-15 front rims the same, or is there a heavy duty and a light duty rim? Perhaps this is just an issue of some aftermarket rims being cheaply made. I have a bucket on the front, so I want to be sure to get the correct rim.
Because the first link (wengers) does not mention anything about 'not' have a front end loader, does that mean it should be fine. Thanks. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 17 Dec 2018 at 5:46pm |
Aftermarket rims come both ways: light duty and heavy duty. If it says "not for use with a loader" avoid it!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55261 |
Posted: 17 Dec 2018 at 6:09pm |
Check that center and bolt pattern, copy it down, and take it to a auto junkyard. I think the bolt pattern and center hole matches up to an old buick station wagon. Might be a little cheaper than $84/rim...
That stuff about loader or non loader may just be about liability, don't know, but I know my D-12 works fine, on a pair of old wagon wheels that originated on an old car... And I have about 3-400 lbs ectra weight, on the front of it...
JamesG
Posted: 17 Dec 2018 at 6:22pm |
Yes, it would be great if the rim matches something in the junk yard. I will give that a try first. Thanks all for the ideas.
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 18 Dec 2018 at 7:31pm |
I fully agree with Dave... there is normal use with a loader and then there is ABuse. He is right about old full size Buick rims from the early sixties (likely late fifties as well) and up into the seventies will fit providing you have a 5 stud hub on your D15. From '65 and up Buick rims have a smaller center hole but you can cut the hole bigger with a torch. They are heavy duty rims as the cars were heavy. From '71 and up you can use rims from Chevy full size cars by just enlarging the center hole, I've done it for A-C farm tractor application. Being that you have the industrial model you're sure to have power steering. The benefit with A-C original rims is that you have narrow tires giving good help turning a non power steering tractor.
HD6GTOM
Posted: 19 Dec 2018 at 5:53pm |
James, there is a whole lot of difference for an industrial rim and a standard rim. You are not going to find a Buick rim in 16". They were all 15". When I owned the tire shop, I got my heavy duty rims from the local JD dealer. They were painted white. They were as cheap as my whole sale suppliers and when I got them I knew they were heavy duty. A rim off a wagon is not heavy enough for your tractor. The centers are too thin.
Edited by HD6GTOM - 19 Dec 2018 at 5:54pm |
DiyDave
Posted: 19 Dec 2018 at 6:06pm |
True enough, didn't see that the wenger's rim was 16". But, singe there's no brake trum, a 15" will prolly still work, as long as the wheel center is correct.
Eric B
Posted: 22 Dec 2018 at 7:24pm |
There is no problem using 15'' rims for clearance. On one of my A-C's I have a set of 14" wheels that would be late 50's Oldsmobile, same 5 stud bolt pattern and no clearance issues whatsoever.
