D-15 Series I industrial, Hydraulic Pump |
JamesG
Joined: 27 Jul 2015 Location: NewEngland Points: 26 |
Topic: D-15 Series I industrial, Hydraulic PumpPosted: 21 Dec 2015 at 9:35pm |
My front mounted D-15 hydraulic pump is leaking. Are there any replaceable gaskets or seals to fix this, or do I need to look for a new pump. Either way where can I get the parts I need? Thanks.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55294 |
Posted: 22 Dec 2015 at 5:05am |
Take it off, and check with a local rebuilder. I use Advanced fluid systems, Lancaster PA.
Also, if the tag is legible, on the pump, Check with surpluscenter.com and see if they have a will fit replacement...
