D-15 racing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: D-15 racing
    Posted: 14 Mar 2017 at 4:31pm
Hi guys, getting hammered with snow a the moment. Dads plowing with our D-15 series II, he probably pushing 3/4 throttle then when he puts stick into neutral to shift to reverse. Well as soon as hand clutch comes out into neutral the tractor reves up a lot higher. I can remember as kid it didn't do that, would just stay at about 3/4 throttle. What do you think is going on. Something in govaner.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 5:34pm
Check the AC shop manual.  You need to bend the carb-gov linkage, to correct the problem...Wink
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 6:16pm
The vertical governor post is corroded or just stuck...we had to disassemble mine to get the right parts to pivot...if it sticks it will act like it is racing...Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 10:34pm
Ok thanks. Will look into those things
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2017 at 4:37am
Keep your snow up there, please.
This page was generated in 0.110 seconds.
