D15 pushrods vs. B,C,CA
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Topic: D15 pushrods vs. B,C,CA
    Posted: 10 Oct 2011 at 7:27am
Would anyone know what the difference is between the B,C &CA  (70207426) pushrods vs. the D10,D12,D14 & D15 (70227633) pushrod? I need three for a D15, and I was hoping the older ones would work.
Thanks!
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 10:19am
B_C_CA    Push  rods  are 9-7/8  long.  I don`t  have  a 149  push rod left  to measure , but  the  are  way  different.  Tony
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 10:59am
Is your D15 a 149 Cu in, or 160?  If it's a 160, you would be happy to pay the the price of the 149. I have 3 of the 160's.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 11:25am
It is a 160. On the Agco online parts lookup I don't see where there is any difference between the 149 and 160 pushrods.
Do you want to sell 3 of them?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 1:14pm
I have a tub that has 50 or more push rods from B's, C's, CA's and one D-15. I have looked thru them a few times and have not found any pushrods that were different. I have never spent a lot of time getting more than a good set out of the tub at a time. It has been ten years or more since I chucked the D-15 pushrods in that tub but if they had looked different I would not have tossed them in there.  I do know that the lifters are the same and carry the same aftermarket part numbers. So the down end would have to be the same. As I remember the head bolts and rocker arms were the same also which would lead me to believe with the head the samre thickness that the pushrods were the same.  I would bet they would work in any case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 2:11pm
OK, I got one out and measured from the D15. 9-3/16" overall length, so they are shorter then the B,C,CA pushrods.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 7:36pm
  yes they are differentinlength  have some of both   1-800-254-3116 tappet end is also different
