D15 power steering
obdhd4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote obdhd4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 power steering
    Posted: 24 Jul 2011 at 1:27pm
Out mowing w/ d15 ser II-power steering suddenly quits- very stiff thru the middle, seems ok once turned rt or left. Plenty of fluid, but cap is missing and green scrubby stuffed in place. Any ideas- don't want to tear anything apart un-necessarily-really like using this tractor! Thanks to all, Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 6:24pm
So a good (and cheap) place to start is to lube up the splined coupler underneath the generator AND the bushing block bolted inside the left side rail....make sure these are oily so there is no binding. Also consider oiling the steering wheel column (easier said than done).
