D15 noise
acdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave Quote  Post ReplyReply Direct Link To This Post Topic: D15 noise
    Posted: 19 May 2010 at 9:15pm
I bought my uncle's D15. It has a howling noise coming from the rear end. I remember it did this when I used to use it but it is worse now. It does it in 4th gear when it is pulling but not when it is going down hill. Any ideas?
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:23pm
Do the Bull Gear Compartments have oil in them?
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:24pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 10:06pm
 If every compartment is full of oil, it sounds like the typical ring and pinion gear whine(road gear only)....some are VERY noisey....and as soon as you crest a hill and remove the load the noise pretty much goes away.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 6:20am
My old D-15 did exactly what the Dr. describes, been told do not worry.
MikeSMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeSMN Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:26am
1964 D15 II - Acts the same way - only in road gear & only when there is a load on the drive train.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:40am
Got one does it also. Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:45am
Mine actually does the same thing...just drove it yesterday.
"Better By Design"
This page was generated in 0.052 seconds.
