D15 need an over run clutch for brush hog?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: D15 need an over run clutch for brush hog?
    Posted: 08 Jul 2019 at 4:03am
I've been told I needed a overrun clutch for a model CA to run a brush hog, but would a model d15 need one?( How do these overrun clutch work?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 4:58am
Really with both tractors mentioned, its a toss up. with a CA, and you stop with the axle clutch, you get the same effect as stopping a D-15 with the PD...
ORC'a are needed on tractors like B's and C's, operating bush hogs....Wink
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:32am
D15, no.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:36am
With the PD on a D15 you won't need an ORC, on the CA you won't need one unless the hand clutch has been bolted together rendering it inoperable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 5:59am
Hmm, doesn't an ORC stop the bushhog from destroying the tractor if it hits ,say, a big friggin rock , or the 'ohyeah...THAT stump' ??
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 6:04am
It would never hurt to have a ORC on both tractors. In a panic situation the first natural reaction is to go for the foot clutch.THAT will still send you thru the fence. I dont know how I know that. An over running clutch would have saved you in a panic situation.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 6:20am
That would be a slip clutch. Darrel
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 6:51am
Depends, A person thoroughly familiar with the two clutch system will bang the hand clutch for a panic to stop of forward motion and thus he doesn't need one. If one's first instinct is the foot clutch thats a different deal.
Don't take this personal but since you had to ask, you might want to invest in an O.R. clutch.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 7:27am
I would use one, you might not need it but I find when using one on my 190, I can stop and shift. Otherwise I have to wait until the mower stops turning to shift.
Charlie
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 9:21am
The overrunning clutch passes torque to the mower from the tractor, but goes open when the mower PTO shaft is turning faster than the tractor PTO shaft. That is important for safety when the PTO shaft in the tractor is driven by a shaft in the tractor transmission. Without the ORC the inertia of the mower will make the tractor move even with the engine clutch disengaged and sometimes be stronger than the tractor brakes sometimes causing collisions with trees, power poles or buildings. Important to have an ORC with tractors like the Ford 9N, 2N, and 8N and AC with similar transmissions.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 2:43pm
Ok, thanks for the heads up fellas!
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 2:53pm
I've used a bush hog on a 170 and a D15 S2 and find the ORC is a nice addition as it allows easy shifting, and prevents nasty surprises. Keeps me from running the tractor into the pond:) on occasion.
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:26pm
I use a over run clutch on my 170...I also added a slipper clutch to the drive shaft on my bush hog...it came with a shear pin set up...so now it has both....to much....maybe...but it works for me
The over run clutch sure makes for better shifting of the trans....it let's the trans stop turning so you can shift gears while the bush hog keeps spinning
Get a ORC ...they work good and makes for safer bush hogging
Ocharry
Edited by ocharry - 08 Jul 2019 at 10:29pm
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 10:34pm
Using an allis brush cutter with the over riding clutch with the pins do you still need an additional clutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 4:30am
NoWink
Stevegates01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevegates01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 3:04pm
I work for an agriculture company, they have a lot of land where we grow different plants, trees, flowers and many others. The CEO of the company has many old tractors including d15 which he put up for sale. Recently he bought new new John Deere tractors, they work perfectly and he is very pleased. Moreover, these tractors have different attachments like snow blower and lawnmower. So if you're interested to buy a D15 or maybe to ask for some details, you can visit this webpage https://www.growgardener.com/best-brush-cutter-for-stubborn-brush/ and see the contacts of my boss, he can tell you more information.
Edited by Stevegates01 - 16 Jun 2020 at 7:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 5:19pm
Originally posted by Stevegates01 Stevegates01 wrote:
I work for an agriculture company, they have a lot of land where we grow different plants, trees, flowers and many others. The CEO of the company has many old tractors including d15 which he put up for sale. Recently he bought new new John Deere tractors, they work perfectly and he is very pleased. Moreover, these tractors have different attachments like snow blowers and lawnmowers.
What are these john deere tractors you speak of?  Never heard of em...Wink
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 5:41pm
Are there other attachments that need an ORC?.
I  think you should get the ORC, because when in a panic it seems natural to hit the clutch and brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2020 at 6:35pm
Dear "Stevegates01" :  Sure glad your CEO is happy with the new John Deere tractors that are 55+ years newer in age than his old Allis-Chalmers D-15. Not sure why in Sam Hill you think that is important, but have a nice day anyway.  D-15's had many optional attachments for them as well that you apparently aren't aware of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 12:13am
What he said. In a panic most people stomp on the foot clutch and brakes.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2020 at 9:59pm
If you buy an over running clutch, buy a good one. Two friends of mine have been killed by N Ford's when the overrunning clutch locked up and they were pushed over cliffs winding up under the mowers. An friend of Dads was killed by an MT John Deere being pushed into a deep ditch because he did not have an overrunning clutch on his mower.
