D-15 Loader problems
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Loader problems
    Posted: 09 Apr 2011 at 8:47pm
Amonth ago I installed an Allis 140 loader on my D-15. It worked great. Would stay up for hours. 2 weeks ago I wanted to lift a tire & rim, but the loader wouldn't go high enough. I checked fluid and it was low. So I added some and it worked fine. No I didn't check it before with the rams extended. Today it wouldn't lift off of the ground. Check fluid again, none on the dipstick. I checked the power director and it's over full. I guess a seal is leaking between the 2 chambers. It looks like I have to split the tractor at the transmission to get at this. Any advise? Thanks Bob
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 8:49pm
Piston hose in the housing leaking?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:42pm
Are you sure the PD is over full, not the trans.? If the PD is over full then you will have to remove the torque tube to instal the seal, unless a plug has come out between the pump and PD.
 If trans. is over full you will have to remove the rear cover and replace cylinder seals and hose.    MACK
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:44pm
Try disconnecting the hose/tube going to the rear lift arms and capping it off.  If the hose inside is bad, things should work ok without it connected.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2011 at 9:55pm
The level in the trans is normal. I checked that first.
Mack, Where is the plug you are talking about?
Eldon, I want to use the rear lift for my plow later. Gotta limp through until the plowing is done. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2011 at 2:47pm
The fluid in the PD was milky, which tells me it had water in it.
As I refilled (overfilled) the Hydraulic compartment, I still had the plug out for the PD area and nothing was leaking. Of course, the tractor was not running. Bob
