D15 industrial diesel |
elec
Topic: D15 industrial dieselPosted: 23 Sep 2021 at 6:50pm |
I have a d15 diesel. Serial number D15 4349D. It is a bare back. Wondering if the rear arms off of a d14 will fit so I can put a 3 point on it.
Side note for a good laugh: my father-in-law, a certified diesel mechanic, has been working on the d15 diesel for a few months now. He reinstalled the injector pump and it took him quite a while to realize the shut-off was backwards (pull to run, push to shut off) and that's why he couldn't get it to start!
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5226 |
Posted: 23 Sep 2021 at 7:20pm |
Yes a D14 rear housing will fit onto a D15. You will also need the cylinder and most likely the pump under the power director, along with the traction booster spring/snap coupler. Unless it has a loader and you want to splice into that system to have just Lift/Lower without the traction booster.
elec
Posted: 23 Sep 2021 at 7:34pm |
Thanks for the quick response.
Yes it has a loader. I need a new valve on it to run the grapple so I will get a 4 spool valve. No need for traction booster. Do I need to cap off PTO whole or can I install a PTO shaft since I have a shuttle? |
PaulB
Posted: 24 Sep 2021 at 6:52am |
The PTO in a shuttle equipped tractor will not run at the normal speed. If you are thinking of running a Brush-Hog, you're out of luck.
elec
Posted: 24 Sep 2021 at 10:52am |
No. Just want to keep oil in
