D15 II power director oil
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: D15 II power director oil
    Posted: 06 May 2012 at 9:54am
What do y'all use? I'll bet not the 20W the book says. Hytrans?
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:02am
Captain .. i drained my D 15  II  , actually drained all oil out over the winter , and in the power director , i used Cenex  HTB
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:34am
Dana,
I have used the Tractor Supply version of Universal Tractor Hydraulic Fluid and they tend to carry two brands in most stores; Traveller and Mystic. May leak slightly more around old seals that are already showing a slight leak (thinner fluid) but both of the above work well down here, even with over 70 days above 100F in our area last year. I see recently that TSC now offers a "High Mileage" type of the above, for "older tractors that required straight oil originally" and it is supposed to be a bit thicker viscosity. Whatever you use, make sure it shows "Allis Chalmers 821" on the label where compatibility of other brands are listed. I run Traveller or Mystic in all eight, including three D15II's, the D17IV and the D19D and never had an issue. (the D19D is the unit I brought down from Herkimer that we talked about last year)
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 11:38am
The universal hydraulic fluids, or Hytran fluids are a 20 weight oil. Just much better protection for gears and bearings than the old straight 20 weight non-detergent oil.
