D15 II manifold |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7511 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2016 at 9:25am |
Is there any way to keep the pipe that threads into the manifold from working its way loose? I tighten it down with a pipe wrench but will be loose 10 minutes later. I do not want to weld it in place.
I appreciate any ideas! |
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Bore side and put in setscrew.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Look the threads inside the manifold and the ex pipe first, if they are good and the pipe threads down inside the manifold good then remove the pipe and start and run the tractor in tell it's up to temp them install the cold pipe in a hot manifold, get it cool down and see if it stays put.
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Finda tap clean the thread's up take a torch heat the manifold good and hot then quickly screw a cold new nipple in and tighten with a pipe wrench when it cools it will be there forever
