D15 II manifold
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 II manifold
    Posted: 30 Jul 2016 at 9:25am
Is there any way to keep the pipe that threads into the manifold from working its way loose?  I tighten it down with a pipe wrench but will be loose 10 minutes later.  I do not want to weld it in place.
I appreciate any ideas!
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 9:36am
Bore side and put in setscrew.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 9:38am
Look the threads inside the manifold and the ex pipe first, if they are good and the pipe  threads down inside the manifold good then remove the pipe and start and run the tractor in tell it's up to temp them install the cold pipe in a hot manifold, get it cool down and see if it stays put.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 10:18am
Finda tap clean the thread's up take a torch heat the manifold good and hot then quickly screw a cold new nipple in and tighten with a pipe wrench when it cools it will be there forever
This page was generated in 0.266 seconds.
