D15 II Distubutor wont turn
Tireguy58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireguy58 Quote  Post ReplyReply Direct Link To This Post Topic: D15 II Distubutor wont turn
    Posted: 10 Jul 2015 at 3:40pm
Trying to get an old tractor running. When I got the tractor it had a blown head gasket but I could get it to start and run long enough to load. Replaced the head gasket and new intake manifold. Put new plugs,wires,coil,cap and rotor on it. Try to start it no spark. Pulled cap off and distrubitor is not turning. Any help would be greatly apprecated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 4:02pm
More than likely, the Distributor main shaft gear is completely worn out and not turning with the drives main shaft gear. If that's the case you may need to change both the Drive gear and Distributor main shaft gear being they mech together. Also, I've seen happen is the Distributor main shaft freeze in the oilite bushing. In either case, its time for a rebuilt Distributor and drive. Whats the number of the Distributor off its tag? Could be an 1112607 Delco. The Gas and LPG D15 Tractors ran that model Distributor...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireguy58 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 4:07pm
Distrubitor number 1112609 3b2j
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireguy58 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 4:08pm
Delco-remy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tireguy58 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 5:01pm
Pulled front off governor. Weights are in little pieces and large gear is missing teeth. Also cracked front housing on governor. Where can I find parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2015 at 8:32pm
I have a restored drive that was off a CA. Not sure if its the same. Maybe somone could varify that...
This page was generated in 0.077 seconds.
