D15 II Crank End Play |
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3524 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Sep 2010 at 6:07pm |
set the crank in the 15 II block today. End play was 2 to 3 thou. That is tight according to the manual but she spins freely. I think I am good to go with that.
what do you all think?
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
When the motor gets hot the parts expand and the clearance gets smaller. I would go with what the book says. What is the clearance supposed to be?
my book says 4 to 8
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 20976 |
I sure wouldn't worry about it....use 5W-20 or 5W-30 for break-in oil and you'll be fine if it truly has .002" to .003" which is enough room for oil to squirt thru.
thanks Dr Allis. Yep I measured it a bunch of times and got the same thing.
