D15 Ignition switch help?
Smitchell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitchell Quote  Post ReplyReply Direct Link To This Post Topic: D15 Ignition switch help?
    Posted: 15 Mar 2010 at 1:33pm
The 1968 D15 gas that I have posted on here before is in need of a new ignition switch.  The one that is on it is in no way like the ones on my other allis D15s.  I believe it to be factory though, because the hole where it goes, is made to fit it, and not the older larger ignitions on the other tractors I have.  Why the change in the ignition for these models over the older ones?  The only thing I have found that looks close to this ignition is a Lawn mower switch. will this work??  Any help apreciated.  Thanks, Scott
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 1:51pm
Scott
Check with Tony C (Tony's Tractors), Jim D (OK Tractor) or Norm. These folks advertise on this site and most likey provide you with a replacement ignition switch. Best if you have your tractor S/N and model (series I or Series II) handy when you contact them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 2:29pm
I'm about 98% sure you have an Indak brand switch which is just like many rinding mower switches. Check your key, I'll bet it fits just about every riding mower, or just about any other piece of power equipment that has a key.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 2:44pm
Bet it is not the flat key.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 3:09pm
Checked the book. There are (2) switches Indak--70241965 and Delco--70235785.
"Burgie"
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 6:17pm
If it's the half-round key, we have one in stock.  Give me a call 877-378-6543.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 8:20pm
  we have both switches in stock   1-800-254-3116
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2010 at 8:51pm
most of the series II D15's had the flat indak key, They changed it superseded by 235785 part number. Yeh my D15II has that crazy indak key also. It was made that way because it has alot smaller hole for the switch than the earlier ones.
