D15 I Hydraulic Pump Rebuild
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 7:56pm
My apologies.
Yes it was 2,000. After refreshing o-rings and NOT changing shims, I got 2,500. I then took it out again, added shims, and still only have 2,500.
The rear arms will lift all my implements. The loader will not lift a bale, or even a full load of dirt. I also am not looking to go through the whole process of adding a new live pump system, if fixing an unoptimized OEM part can get me what I need.
The hold position, lower, traction booster, and raising always worked good, and continued to work good as I used the tractor today. There was a leak from around the remote transport valve, but tightening that stopped the leak, and even with the full cultivator on the arms will stay raised for a good week before they've sagged noticeably.
Not getting peak pressure is the problem, seems to be the only problem.
Getting bigger cylinders is also a solution. But then the loader would be slower.
I want things working right, before I decide I need to change things.
Edited by MadCow - 04 May 2024 at 8:04pm
This page was generated in 0.035 seconds.
