D15 Henry Backhoe Parts
lewy69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy69 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2014 at 4:20pm
I could really use some part info on the mark iv & v backhoes. send me an email and lets talk. Thanks
Snowbusman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snowbusman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 3:22pm
Do you still have the cylinderavailable? I realize its a long time since you postedut I am new to this
Bob
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 2:55am
isn't that what Desert Joe was rebuilding? he gots his parts for the swing. check his post in farm equipment
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 5:25pm
IF your are saying the down force on the hoe and the lifting capacity is not to par , then you need to check hyd pressure as the dipper cylinder when energised should be able to lift the machine - or be able to after lifting machine swing it side to side . also crowd cylinder should be able to pull machine backwards or push it forward
If good pressure - then you have internal leakage on the cylinder piston .
Edited by Coke-in-MN - 22 Oct 2016 at 5:26pm
pbqc3803 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pbqc3803 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 2:32am
Awesome picture truce 1000. I have the same tractor as yours. Mine just looks more worn out. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 4:47am
4 year old post...
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 7:10am
Sure think that is what I sent Joe
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
