D15 Floating Oil Screen
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Topic: D15 Floating Oil Screen
    Posted: 31 May 2020 at 8:46pm
I went to change the oil in my D-15 and suspected something was up with the oil screen because I could feel the screen right over the drain plug hole. I took off the oil pan and sure enough the screen was off the pipe. It has broken right where the pipe goes in the screen.
The part number is 229541. Does anyone know a good source. I may have to go to the tractor yard in Pavo, GA, but I would like to avoid that trip it is probably a 150 miles one way.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 8:48pm
Braze it back on or have one shipped.       MACK
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 10:23pm
Pretty sure I have a NOS one, can check when im in the shop otomorrow
www.awtractor.com
A&W TRACTOR 920-598-1287
