D15 factory 3 point
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: D15 factory 3 point
    Posted: 01 Jan 2024 at 7:23pm
Searching for factory 3 point parts for a series 2 D15. Partial parts or the entire system. Thanks.
allis1221G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2024 at 1:30pm
I have one. Complete 616-334-0844
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2024 at 11:13pm
What parts exactly are you needing?
Andrew Gubbels
Gubbels Restoration
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2024 at 11:02am
Still looking for the factory top link bracket. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 10:39am
Looking for a draw bar also.
jonwalter1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonwalter1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 6:52pm
Is that factory 3 pt still available or does anyone know of another one that could be bought (whole assembly).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:09pm
I actually bought that one. Hopefully another one will pop up on here for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonwalter1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:20pm
Ok, thanks for the update!
How was the installation? I've got the 3 pt conversion, but not a fan of how it attaches across the draw bar (very loose). If I could find an original I'd prefer that over doing more welding and tinkering to make the adapter work better. Hoping to restore the girl next year which would be an ideal time for the swap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:37pm
The installation was actually really simple, it was definitely worth it. Only took a couple hours to do. Mine had an aftermarket conversion on it and In my opinion the factory one is a lot nicer. I also found a factory 3 spool hydraulic valve for it and installed that also and it really works great. So if you find one of those I think you would like it
Edited by Model 70 - 08 Nov 2024 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 7:41am
Have a good draw bar and whole complete 3 pt
