D15 diesel tach drive
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel tach drive
    Posted: 17 Mar 2026 at 3:16pm
I put a new tachometer and cable on my D15 diesel.  The tach cable did come from Steiners and said it fit the D15 and D17 diesels.  The issue is where it connects to the engine.  As you can see, there is a problem.  Can that stem sticking out of the engine block be removed and allow the cable to fit (and work)?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 3:18pm
Yes that is part of the old cable
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 4:14pm
You will need to remove the drive from the block and disassemble to remove the old broken piece of the drive cable. What is stuck in there is what you see at the end of your new cable. I have a thread on the forum concerning my D17 diesel cable was stuck but not broken. I included pictures also.
Edited by AC720Man - 17 Mar 2026 at 4:16pm
